I’m having an issue trying to use the Monitor Location with Plex and PlayOn
I have a Monitor Location set for PlayOn - which I use to record Netflix and miscellaneous shows.
For Plex I have post processing enabled thru a batch file using the CLI to add files to MCEBuddy
I recently tried to setup a separate Conversion Task for PlayOn and in the expert settings I selected Monitor Location and for the PlayOn conversion task selected the PlayOn monitor location.
I did the same for the Plex conversion task but only selected the Manual / CLI
But none of my Plex files are bring converted - I’m receiving the following message - disregard the show it’s just for testing purposes
WARNING> 2018-02-09T11:36:55 MCEBuddy.Engine.QueueManager --> Manually selected file J:\TV Shows.grab\589bffc5250d165b606e6193523dd118af9662e9\The Dish With Rachael Ray (2008) - 2018-02-09 11 00 00 - Episode 02-09.ts does not exist or MCEBuddy doesn’t have read permissions, skipping
I should also mention that if I take out the Monitor Locations in the Expert settings that the Plex script now works but that I get 2 conversion tasks for PlayOn
I’m guessing that maybe this could be a Plex issue . . .but I’m not sure as it does seem like it’s getting passed thru to MCEBuddy
Or is there another way to do this?
I’m looking to have a directory perform a specific conversion task while the other shows from Plex be run thru a different conversion task.
Check your folder/flle permissions. MCEBuddy runs as a system service using the LocalSystem credentials. Your file permissions must provide LocalSystem with read/write credentials and that should solve the issue.
I didn’t understand your other point, by default every conversion task will process every file from every monitor location. The point of the expert settings monitor location is to link the conversion task to process files only from certain monitor locations. So if you remove that binding, then the conversion task will process files from every monitor location that you have defined.
Thanks for the reply and I’m not sure that it’s related to file permissions.
If in my Conversion Task I have Monitor Location (Expert Settings) set to monitor Manual / CLI for my Plex conversion task then I get the above warning. If Monitor Locations (Expert Settings) isn’t checked then all of my Plex recordings are collected and processed by MCEBuddy. I’ve been running this setup for at least six months now with no issue until I decided to try and split out the PlayOn conversion task.
And correct that is what I am trying to do - tie a specific directory that is being monitored to a specific conversion task.
I did check on the local user and it didn’t have Full Control of the grab directory but the user is part of the Admin group that does . . . I’ve granted the user Full Control and will test later today as there are some Plex recordings that are still processing from overnight.
I’ve maybe narrowed it down a bit more - it seems to be in the Monitor Location when I tell it to Monitor Subdirectories . . . here’s the log and you can see the failures at the bottom. I’ve unchecked monitor subdirectories for the PlayOn task and have a couple of Plex recordings running now so we will see if they process once they complete.
Hmm not sure how to attached a file . . .so here’s a wall of text
INFORMATION> 2018-02-12T10:49:56 MCEBuddy.Engine.Core --> MCEBuddy engine stopped
INFORMATION> 2018-02-12T10:49:56 MCEBuddy.Engine.Core --> Setting engine last running state to stop
2018-02-12T10:49:56 MCEBuddy.Engine.Core --> Loaded MCEBuddy engine settings
INFORMATION> --> Windows OS Version -> Microsoft Windows NT 10.0.16299.0 (WIN_10_2016_SERVER, Professional)
INFORMATION> --> MCEBuddy Build Version : 2.4.8.1
INFORMATION> --> MCEBuddy Build Date : 01/24/2018 17:02:36
--> Locale Language -> ENG
2018-02-12T10:49:56 MCEBuddy.Engine.Core --> MCEBuddy engine settings -> CONVERSION TASK OPTIONS ==>
Task -> H.265 - Football
Profile -> HEVC MKV
Source File ->
Relative Source Path ->
Destination Path ->
Working Path ->
Fallback Destination -> False
Skip ReProcessing -> False
Add to WMP Library -> False
Max Width -> 7680
Quality Multipltier -> 1
FPS ->
Auto DeInterlacing -> True
Prefer Hardware Encoding -> True
Volume Multipltier -> 1.2
DRC -> True
Force Stereo -> False
Profile Audio Language ->
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
Closed Captions Offset -> 2.5
Embed Subtitles -> False
Embed Chapters -> False
Commercial Removal -> Comskip
Custom Comskip INI Path ->
Search Ad markers from chapters -> False
Keep Advertisements -> False
Download Series Details -> True
Download Banner -> True
Overwrite Title from Internet -> False
Prioritize matching by Original Broadcast Date -> False
Force Show Type -> Default
Write Metadata -> True
Rename by Series -> True
Alt Rename by Series -> True
Custom Rename by Series ->
Rename Only -> False
File Selection Pattern ->
Show Selection Pattern -> *NFL Football*
Channel Selection Pattern ->
Codec Type Selection -> Any
DRM Type Selection -> All
Monitor Tasks Selection -> Manual/CLI files
Extract XML -> False
Disable Cropping -> False
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
Task Enabled -> True
Task -> H.265 HEVC MKV - PlayOn
Profile -> HEVC MKV
Source File ->
Destination Path ->
Working Path ->
Max Width -> 7680
FPS ->
Volume Multipltier -> 0.6
DRC -> True
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
Commercial Removal -> None
Rename by Series -> False
Alt Rename by Series -> False
Show Selection Pattern -> ~NFL Football*
Monitor Tasks Selection -> PlayOn
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
Task -> H.265 HEVC MKv
Profile -> HEVC MKV
Source File ->
Destination Path ->
Working Path ->
Max Width -> 7680
FPS ->
DRC -> True
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
MONITOR TASK OPTIONS ==>
Task -> PlayOn
Search Path -> F:\PlayOn
Search Pattern -> *.dvr-ms;*.wtv;*.asf;*.avi;*.divx;*.dv;*.flv;*.gxf;*.m1v;*.m2v;*.m2ts;*.m4v;*.mkv;*.mov;*.mp2;*.mp4;*.mpeg;*.mpeg1;*.mpeg2;*.mpeg4;*.mpg;*.mts;*.mxf;*.ogm;*.ts;*.vob;*.wmv;*.tp;*.tivo
Search Path Exclude ->
Monitor Delete Original -> False
Monitor Archive Original -> True
Monitor Archive Folder ->
Monitor SubDirectories -> True
Monitor Converted Files -> False
ReMonitor Recorded Files -> False
Minimum Age -> 1
Domain Name ->
User Name ->
Password ->
GENERAL OPTIONS ==>
Domain Name ->
User Name -> Guest
Password ->
Wake Hour -> -1
Wake Minute -> -1
Start Hour -> -1
Start Minute -> -1
Stop Hour -> -1
Stop Minute -> -1
Days of Week -> Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday
Max Concurrent Jobs -> 1
Enable Job Logs -> True
Log Level -> 3
Log Keep Days -> 15
Use Recycle Bin -> False
Delete Manually/CLI added Original -> False
Archive Manually/CLI added Original -> True
Sync Converted -> False
Allow Sleep During Conversions -> True
Pause Conversion on Battery Power -> True
Send eMails -> False
eMail settings -> Send eMail Settings -> SMTP Server ->
Port -> 25
SSL -> False
User Name ->
Password ->
From ->
To ->
Bcc ->
eMail On Success -> True
eMail On Failure -> True
eMail On Cancellation -> True
eMail On Start -> True
eMail On Queueing -> True
Skip eMail Body for notifications -> False
Locale -> en-US
Temp Working Path ->
Archive Folder -> J:\TVShows_Archive
Failed Folder ->
Space Check -> True
Custom Comskip Path -> C:\comskip\comskip.exe
Custom profiles.conf -> C:\Program Files\MCEBuddy2x\config\Custom_profiles.conf
App Hang Timeout -> 300
Scan New Files Poll Period -> 300
Process Priority -> Normal
CPU Affinity -> 0
Engine Running -> False
Subtitle Cut Segment Incremental Offset -> 0
Local Server Port -> 23332
UPnP Enabled -> False
Firewall Exception Enabled -> False
2018-02-12T10:50:39 MCEBuddy.Engine.Core --> Loaded MCEBuddy engine settings
2018-02-12T10:50:39 MCEBuddy.Engine.Core --> MCEBuddy engine settings -> CONVERSION TASK OPTIONS ==>
Profile -> HEVC MKV
Source File ->
Destination Path ->
Working Path ->
Max Width -> 7680
FPS ->
DRC -> True
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
Profile -> HEVC MKV
Source File ->
Destination Path ->
Working Path ->
Max Width -> 7680
FPS ->
DRC -> True
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
Profile -> HEVC MKV
Source File ->
Destination Path ->
Working Path ->
Max Width -> 7680
FPS ->
DRC -> True
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
TiVO MAK Key ->
Domain Name ->
User Name ->
Password ->
Task -> PlayOn
Minimum Age -> 1
Domain Name ->
User Name ->
Password ->
GENERAL OPTIONS ==>
Domain Name ->
User Name -> Guest
Password ->
Wake Hour -> -1
Wake Minute -> -1
Start Hour -> -1
Start Minute -> -1
Stop Hour -> -1
Stop Minute -> -1
Log Level -> 3
Log Keep Days -> 15
Port -> 25
SSL -> False
User Name ->
Password ->
From ->
To ->
Bcc ->
Locale -> en-US
Failed Folder ->
Space Check -> True
CPU Affinity -> 0
2018-02-12T10:50:39 MCEBuddy.Engine.Core --> MCEBuddy engine started. Setting engine last running state to start.
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Wynonna Earp\Season 2\Wynonna Earp - s02e08 - No Future in the Past.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Blood Drive\Season 1\Blood Drive - s01e03 - Steel City Nightfall.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Zoo\Season 3\Zoo - s03e02 - Diaspora.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Wynonna Earp\Season 2\Wynonna Earp - s02e09 - Forever Mine Nevermind.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Strain\Season 4\The Strain - s04e03 - One Shot.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Stitchers\Season 3\Stitchers - s03e08 - Dreamland.mkv already converted with status OutputFromConversion
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Shadowhunters\Season 2\Shadowhunters - s02e18 - Awake, Arise, or Be Forever Fallen.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Salvation\Season 1\Salvation - s01e04 - The Human Strain.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Preacher\Season 2\Preacher - s02e07 - Pig.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Orphan Black\Season 5\Orphan Black - s05e08 - Guillotines Decide.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Mist\Season 1\The Mist - s01e07 - Over the River and Through the Woods.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Midnight, Texas\Season 1\Midnight, Texas - s01e02 - Bad Moon Rising.mp4 already converted with status Error
2018-02-12T10:50:40 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Killjoys\Season 3\Killjoys - s03e05 - Attack the Rack.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Fargo\Season 3\Fargo - s03e01 - The Law of Vacant Places.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Dark Matter\Season 3\Dark Matter - s03e09 - Isn't That a Paradox_.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Dark Matter\Season 3\Dark Matter - s03e10 - Built, Not Born.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Netflix\3-Headed Shark Attack.mkv already converted with status OutputFromConversion
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Van Helsing\Season 1\Van Helsing - s01e04 Coming Back.mkv already converted with status OutputFromConversion
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Van Helsing\Season 1\Van Helsing - s01e05 Fear Her.mkv already converted with status OutputFromConversion
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Van Helsing\Season 1\Van Helsing - s01e06 Nothing Matters.mkv already converted with status OutputFromConversion
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Van Helsing\Season 1\Van Helsing - s01e07 For Me.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Van Helsing\Season 1\Van Helsing - s01e08 Little Thing.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e01 - Dragonstone.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e01 The H Word.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e02 Mean Right Hook.mp4 already converted with status Error
2018-02-12T10:50:41 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e03 Worst Behavior.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e04 Royal Dragon.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e05 Take Shelter.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e06 Ashes, Ashes.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e07 Fish in the Jailhouse.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's The Defenders\Season 1\Marvel's The Defenders - s01e08 The Defenders.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e02 - Stormborn.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e03 - The Queen's Justice.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e04 - The Spoils of War.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e05 - Eastwatch.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e06 - Beyond the Wall.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e01 Snow Gives Way.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e02 Shadow Hawk Takes Flight.mp4 already converted with status Error
2018-02-12T10:50:42 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e03 Rolling Thunder Cannon Punch.mp4 already converted with status Error
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e04 Eight Diagram Dragon Palm.mp4 already converted with status Error
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e05 Under Leaf Pluck Lotus.mp4 already converted with status Error
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e11 The Path of the Righteous.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e10 Nelson v. Murdock.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e09 Speak of the Devil.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e08 Shadows in the Glass.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e05 World On Fire.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e13 Daredevil.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e07 Stick.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e06 Condemned.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e04 In the Blood.mkv already converted with status Cancelled
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e06 Immortal Emerges from Cave.mkv already converted with status OutputFromConversion
2018-02-12T10:50:43 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e07 Felling Tree with Roots.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e08 The Blessing of Many Fractures.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e09 The Mistress of All Agonies.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e10 Black Tiger Steals Heart.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e11 Lead Horse Back to Stable.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e12 Bar the Big Boss.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Iron Fist\Season 1\Marvel's Iron Fist - s01e13 Dragon Plays with Fire.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Netflix\Avalanche Sharks.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Netflix\Raze.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 4\Marvel's Agents of S.H.I.E.L.D. - s04e01 The Ghost.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 4\Marvel's Agents of S.H.I.E.L.D. - s04e02 Meet the New Boss.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 4\Marvel's Agents of S.H.I.E.L.D. - s04e03 Uprising.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e01 Pilot.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e02 0-8-4.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e03 The Asset.mkv already converted with status OutputFromConversion
2018-02-12T10:50:44 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e04 Eye Spy.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e05 Girl in the Flower Dress.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e06 F.Z.Z.T.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e07 The Hub.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e08 The Well.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e09 Repairs.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e10 The Bridge.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e11 The Magical Place.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e12 Seeds.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e13 T.R.A.C.K.S..mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e14 T.A.H.I.T.I..mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e15 Yes Men.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e16 End of the Beginning.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e17 Turn, Turn, Turn.mkv already converted with status OutputFromConversion
2018-02-12T10:50:45 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e18 Providence.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e19 The Only Light in the Darkness.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e20 Nothing Personal.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e21 Ragtag.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 1\Marvel's Agents of S.H.I.E.L.D. - s01e22 Beginning of the End.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e01 Shadows.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e02 Heavy Is the Head.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e03 Making Friends and Influencing People.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e04 Face My Enemy.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e05 A Hen in the Wolf House.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e06 A Fractured House.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e07 The Writing on the Wall.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e08 The Things We Bury.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e09 Ye Who Enter Here.mkv already converted with status OutputFromConversion
2018-02-12T10:50:46 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e10 What They Become.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e11 Aftershocks.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e12 Who You Really Are.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e13 One of Us.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e14 Love in the Time of Hydra.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e15 One Door Closes.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e18 Frenemy of My Enemy.mp4 already converted with status Error
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e16 Afterlife.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e17 Melinda.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e19 The Dirty Half Dozen.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Manhunt_ Unabomber\Season 1\Manhunt_ Unabomber - s01e01 - UNABOM.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Manhunt_ Unabomber\Season 1\Manhunt_ Unabomber - s01e02 - Pure Wudder.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Midnight, Texas\Season 1\Midnight, Texas - s01e05 - Unearthed.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e20 Scars.mkv already converted with status OutputFromConversion
2018-02-12T10:50:47 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e21 S.O.S._ Part 1.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 2\Marvel's Agents of S.H.I.E.L.D. - s02e22 S.O.S._ Part 2.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e01 Laws of Nature.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e02 Purpose In the Machine.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e03 A Wanted (Inhu) Man.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e04 Devils You Know.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e05 4,722 Hours.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e06 Among Us Hide....mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e07 Chaos Theory.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e08 Many Heads, One Tale.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e09 Closure.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e10 Maveth.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e11 Bouncing Back.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e12 The Inside Man.mkv already converted with status OutputFromConversion
2018-02-12T10:50:48 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e13 Parting Shot.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e14 Watchdogs.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e14 Watchdogs.mp4 already converted with status Converted
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e16 Paradise Lost.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e17 The Team.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e15 Spacetime.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e18 The Singularity.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e19 Failed Experiments.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Gong Show\Season 1\The Gong Show - s01e01 - Will Arnett; Ken Jeong; Zach Galifianakis.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Gong Show\Season 1\The Gong Show - s01e02 - Fred Armisen; Elizabeth Banks; Will Forte.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Gong Show\Season 1\The Gong Show - s01e03 - Dana Carvey; Tracee Ellis Ross; Anthony Anderson.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Gong Show\Season 1\The Gong Show - s01e04 - Ed Helms; Alison Brie; Will Arnett.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e20 Emancipation.mp4 already converted with status Error
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e21 Absolution.mkv already converted with status OutputFromConversion
2018-02-12T10:50:49 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Agents of S.H.I.E.L.D\Season 3\Marvel's Agents of S.H.I.E.L.D. - s03e22 Ascension.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Ash vs Evil Dead\Season 1\Ash vs Evil Dead - s01e01 - El Jefe.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e07 - The Dragon and the Wolf.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e01 - Pilot.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Game of Thrones\Season 7\Game of Thrones - s07e07 - The Dragon and the Wolf.mp4 already converted with status Converted
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Blood Drive\Season 1\Blood Drive - s01e08 - A Fistful of Blood.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e02 - Show and Prove.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Orville\Season 1\The Orville - s01e02 - Command Performance.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e03 - The Principle Is All.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Gotham\Season 4\Gotham - s04e02 - A Dark Knight_ The Fear Reaper.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\How to Get Away With Murder\Season 4\How to Get Away With Murder - s04e01 - I'm Going Away.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Orville\Season 1\The Orville - s01e04 - If the Stars Should Appear.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Hawaii Five-0\Season 8\Hawaii Five-0 - s08e01 - A'ole E 'Olelo Mai Ana Ke Ahi Ua Ana Ia.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Exorcist\Season 2\The Exorcist - s02e01 - Janus.mkv already converted with status OutputFromConversion
2018-02-12T10:50:50 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e04 - I See Money.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e05 - What Kind of Bad_.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e06 - Why Me_.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e07 - Au Reservoir.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Deuce\Season 1\The Deuce - s01e08 - My Name Is Ruby.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Good Place\Season 2\The Good Place - s02e02 - Dance Dance Resolution.mp4 already converted with status Converted
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Ink Master_ Angels\Season 1\Ink Master_ Angels - s01e11 - Angels of the Inner Harbor.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\NCIS_ New Orleans\Season 4\NCIS_ New Orleans - s04e10 - Mirror, Mirror.mp4 already converted with status Converted
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Blindspot\Season 3\Blindspot - s03e08 - City Folks Under Wraps.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\The Gifted\Season 1\The Gifted - s01e10 - eXploited.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Zoo\Season 3\Zoo - s03e06 - Oz Is Oz_orig.mkv already converted with status Converted
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Arrow\Season 6\Arrow - s06e06 - Promises Kept (Ep.606).mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Arrow\Season 6\Arrow - s06e07 - Thanksgiving (Ep.607).mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e02 - Tear Asunder.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e03 - Let Her Go.mkv already converted with status OutputFromConversion
2018-02-12T10:50:51 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e04 - What They Saw.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e05 - The Fallen Woman.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e01 - Pilot.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e06 - Powerless.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e07 - A Civil War.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e09 - Serious Control Issues.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e10 - Dig A Hole.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Life\Season 1\Life - s01e11 - Fill It Up.mkv already converted with status OutputFromConversion
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e03 Rabbit in a Snowstorm.mkv already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e02 Cut Man.mkv already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e01 Into the Ring.mkv already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Daredevil\Season 1\Old\Marvel's Daredevil - s01e12 The Ones We Leave Behind.mkv already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Netflix\The Cloverfield Paradox.mp4 already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e01 AKA Ladies Night.mp4 already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e02 AKA Crush Syndrome.mp4 already converted with status Converted
2018-02-12T10:50:52 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e03 AKA It's Called Whiskey.mp4 already converted with status Converted
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e04 AKA 99 Friends.mp4 already converted with status Error
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e05 AKA The Sandwich Saved Me.mp4 already converted with status Error
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e06 AKA You're a Winner!.mp4 already converted with status Error
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e07 AKA Top Shelf Perverts.mp4 already converted with status Error
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e08 AKA WWJD_.mp4 already converted with status Error
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e09 AKA Sin Bin.mp4 already converted with status Converted
2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : File F:\PlayOn\Netflix\The Cloverfield Paradox.mkv already converted with status OutputFromConversion
WARNING> 2018-02-12T10:50:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : Unable to queue file for conversion - file inaccessible/locked by another process F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e10 AKA 1,000 Cuts.mp4
WARNING> 2018-02-12T10:55:53 MCEBuddy.Engine.QueueManager --> Monitor task PlayOn : Unable to queue file for conversion - file inaccessible/locked by another process F:\PlayOn\Marvel's Jessica Jones\Season 1\Marvel's Jessica Jones - s01e11 AKA I've Got the Blues.mp4
WARNING> 2018-02-12T11:01:16 MCEBuddy.Engine.QueueManager --> Manually selected file J:\TV Shows\.grab\3cc864b3ea75bdb03b0f78f3906f3797710f97f8\Squawk on the Street (2005) - 2018-02-12 00 00 00 - Episode 02-12.ts does not exist or MCEBuddy doesn't have read permissions, skipping
