Hi I purchased MCEBuddy to remove adverts from sky recordings and it is not doing this. It records the program ok but does not remove any adverts. Are there any specific settings for a sky q box ? I am only interested in removing adverts from recorded sky videos. Has anybody out there had the same problem ?
You may want to start by checking the logs to see what Comskip is detecting (no not). If it’s not detecting any commercials you may want to try to use a different ini file what suits your recording or even make your own ini to make it more aggressive to detect commercials. The default settings are based on the most common channels, other providers/channels may need custom tweaks.
Has anybody out there tuned Comskip INI’s for Sky video recordings or tried to. Can anybody help as I need specific settings to get rid of all the adverts. Thanks
