Need help with delete_show_after/before_first_commercial
I finally got comskip to cut commercials pretty accurately now. However When I add 1 to delete_show_after_first_commercial and to delete_show_before_first_commercial things get interesting. It cuts the ending but cuts it about 1 to 2 seconds early at the end of the video but never cuts the ending of the previous show in the beginning of the video. I have to manually cut that out using custom cuts, which is annoying. Can someone guide me in the right direction so I dont have to manually cut the ending of the previous show and have the full ending without missing the last 1 to 2 seconds. Not sure if this helps but there isnt really any commercials between shows, its as soon at the one episode is over it goes right into the next episode.
my log file:
Bar Rescue - S04E20 - Sticky Situation.ts-HD - AD REMOVING-2021-07-02T14-09-45.log (1.7 MB)
my comskip.ini
detect_method=43 ;1=black frame, 2=logo, 4=scene change, 8=fuzzy logic, 16=closed captions, 32=aspect ration, 64=silence, 128=cutscenes, 255=all
validate_silence=1 ; Default, set to 0 to force using this clues if selected above.
validate_uniform=1 ; Default, set to 0 to force using this clues (like pure white frames) if blackframe is selected above.
validate_scenechange=1 ; Default, set to 0 to force using this clues if selected above.
verbose=0 ;show a lot of extra info, level 5 is also OK, set to 0 to disable
max_brightness=60 ;frame not black if any pixels checked are greater than this (scale 0 to 255)
test_brightness=40 ;frame not pure black if any pixels checked are greater than this, will check average brightness (scale 0 to 255)
max_avg_brightness=25 ;maximum average brightness for a dim frame to be considered black (scale 0 to 255) 0 means autosetting
max_commercialbreak=600 ;maximum length in seconds to consider a segment a commercial break
min_commercialbreak=25 ;minimum length in seconds to consider a segment a commercial break
max_commercial_size=125 ;maximum time in seconds for a single commercial or multiple commercials if no breaks in between
min_commercial_size=4 ;mimimum time in seconds for a single commercial
min_show_segment_length=250 ; any segment longer than this will be scored towards show.
non_uniformity=500 ; Set to 0 to disable cutpoints based on uniform frames
max_volume=500 ; any frame with sound volume larger than this will not be regarded as black frame
min_silence=12 ; Any deep silence longer than this amount  of frames is a possible cutpoint
ticker_tape=0 ; Amount of pixels from bottom to ignore in all processing
logo_at_bottom=0 ; Set to 1 to search only for logo at the lower half of the video, do not combine with subtitle setting
punish=0 ; Compare to average for sum of 1=brightness, 2=uniform 4=volume, 8=silence, 16=schange, set to 0 to disable
punish_threshold=1.3 ; Multiply when amount is above average * punish_threshold
punish_modifier=2 ; When above average * threshold multiply score by this value
intelligent_brightness=0 ; Set to 1 to use a USA specific algorithm to tune some of the settings, not adviced outside the USA
logo_percentile=0.92 ; if more then this amount of logo is found then logo detection will be disabled
logo_threshold=0.75
punish_no_logo=1 ; Default, set to 0 to avoid show segments without logo to be scored towards commercial
aggressive_logo_rejection=0
connect_blocks_with_logo=1 ; set to 1 if you want successive blocks with logo on the transition to be regarded as connected, set to 0 to disable
logo_filter=0 ; set the size of the filter to apply to bad logo detection, 4 seems to be a good value.
cut_on_ar_change=1 ; set to 1 if you want to cut also on aspect ratio changes when logo is present, set to 2 to force cuts on aspect ratio changes. set to 0 to disable
delete_show_after_last_commercial=1 ; set to 1 if you want to delete the last block if its a show and after a commercial
delete_show_before_or_after_current=1 ; set to 1 if you want to delete the previous and the next show in the recording, this can lead to the deletion of trailers of next show
delete_block_after_commercial=0 ;set to max size of block in seconds to be discarded, set to 0 to disable
remove_before=0 ; amount of seconds of show to be removed before ALL commercials
remove_after=0 ; amount of seconds of show to be removed after ALL commercials
shrink_logo=5 ; Reduce the duration of the logo with this amount of seconds
after_logo=0 ; set to number of seconds after logo disappears comskip should start to search for silence to insert an additional cutpoint
padding=0
ms_audio_delay=5
volume_slip=40
skip_b_frames=0 ; Set to 1 to force Comskip to skip frames for higher processing speed.
hardware_decode=0 ; Set to 1 to enable hardware accelerated video decoding, only available in donator version
max_repair_size=200 ; Will repair maximum 200 missing MPEG frames in the timeline, set to 0 to disable repairing for players that don't use PTS.
disable_heuristics=4		bit pattern for disabling heuristics, adding 1 disables heristics 1, adding 2 disables heristics 2, adding 4 disables heristics 3, 255  disables all heuristics
delete_logo_file=1 ; set to 1 if you want comskip to tidy up after finishing
output_framearray=0 ; create a big excel file for detailed analysis, set to 0 to disable
output_data=0 ; create a dump of the user data channel, used for CC and XDS (such as V-Chip info). Can be use together with output_framearray to remote debug CC decoding
output_videoredo=0 ; The old videoredo format
output_videoredo3=0 ; The new videoredo v3 format.
output_womble=0
output_mls=0 ; set to 1 if you want MPeg Video Wizard bookmark file output
output_cuttermaran=0
output_mpeg2schnitt=0
output_mpgtx=0
output_dvrcut=0
output_zoomplayer_chapter=0
output_zoomplayer_cutlist=0
output_edl=1
output_dvrmstb=0 ; Set to 1 if you're running DVRMS-Toolbox
output_edlx=0
output_vcf=0
output_bsplayer=0
output_btv=0 ; set to 1 if you want Beyond TV chapter cutlist output
output_projectx=0 ; set to 1 if you want ProjectX cutlist output (Xcl)
output_avisynth=0
output_vdr=0 ; set to 1 if you want XBMC to skipping commercials
output_demux=0 ; set to 1 if you want comskip to demux the mpeg file while scanning
sage_framenumber_bug=0
sage_minute_bug=0
live_tv=0 ; set to 1 if you use parallelprocessing and need the output while recording
live_tv_retries=4 ; change to 16 when using live_tv in BTV, used for mpeg PS and TS
dvrms_live_tv_retries=300 ; only used for dvr_ms
standoff=0 ; change to 8000000 when using live_tv in BTV
cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\""
mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25  /Z %2 %1"
avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n"
dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" "
windowtitle="Comskip - %s"
delete_show_before_first_commercial=1
added_recording=0
If your video has a fixed number of seconds at the beginning of the recording of the previous show then you can use the Cut start option in the conversion task expert settings to trim the first X seconds of the video.
@RBoy it doesnt have a “fixed” number of seconds. its varies from one episode to the other. All though I do have plex dvr set up to start the recording 1 minute before the start time and set it up to stop recording 2 minutes after. Not sure if that helps or not
You can use the cut start and cut end actions to trim the start and end of your recording as defined in your Plex settings, 1 minute at the beginning and 2 at the end. These will be trimmed before comskip kicks in. That may help a bit.
