Merging shows together
I filed a problem over at Greenbutton and this is what came back !
Windows Media Center stitching shows together? - TheGreenButton - Windows Media Center Forums
Never seen it happen. Can’t say if you’re using the free/old version but make sure you’re on the latest version.
If you’re facing an issue please attach your conversion log and we will definitely look into it.
I am using v 2.4.8 the log file size is 627,000kb https://ufile.io/q9rt9
Thanks will check it out.
You can also upload directly to our server, details here:
Do you want me to upload it ?
Yes if you can, that would be great.
Ok its done. Folder Rickt1962 do NOT use Notepad++ to big of a file need to use notepad and it will take along time to load
So I had a look at the logs and it’s working exactly as it’s supposed to.
You’re original WTV file is 13.7GB and 8 hours long. MCEBuddy stripped the commercials from it and reduces it to about 5.5hrs and about 5 GB.
If you scroll to the end of the logs you’ll see the summary as well.
Your issue is Windows Media Center, that’s the culprit which is combining multiple shows into a single recording.
We’ve seen that before and it’s a bug with Windows MC.
Thank You ! For the quick response ! The link I posted at Greenbutton they changed the title of my post. It was titled “All right who is the bad guy” Now I am suspicious they just wanted to sell VideoRedo !
