I have some files that THINK they have been converted, but obviously haven’t as they are still a TS file. I have several folders of files like this even though other subfolders in my monitored directory are working as expected. This is the log entry I get for one file in a monitored folder:
2021-04-07T10:01:33 MCEBuddy.Engine.QueueManager → Monitor task Windows Default : File I:\Media\Recorded TV\Modern Marvels (1993)\Season 15\Modern Marvels (1995) - S15E22 - The Real National Treasure.ts already converted with status Converted
This is the log entry I get for a file I drag in manually:
I:\Media\Recorded TV\Dateline (2016)\Season 01\Dateline (2016) - S01E22 - The Last Dance.ts, Conversion Task ->Convert to MKV
2021-04-07T10:57:40 MCEBuddy.Engine.QueueManager → File >Dateline (2016) - S01E22 - The Last Dance.ts<, checking filename filter >.ts,.m4v<
WARNING> 2021-04-07T10:57:40 MCEBuddy.Engine.QueueManager → File Dateline (2016) - S01E22 - The Last Dance.ts did not match Filename meta data pattern
In between these two items though I get this blurb of errors. I don’t know if this is relevant or not:
> > ERROR> --> Unable to open INI file -> C:\Program Files\MCEBuddy2x\config\history.. Retrying once more. > Error : System.IO.IOException: The process cannot access the file 'C:\Program Files\MCEBuddy2x\config\history' because it is being used by another process. > at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) > at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) > at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) > at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost) > at System.IO.File.InternalReadAllText(String path, Encoding encoding, Boolean checkHost) > at SharpConfig.Configuration.LoadFromFile(String filename, Encoding encoding) > at MCEBuddy.Util.Ini..ctor(String file) > ERROR> --> Unable to open INI file -> C:\Program Files\MCEBuddy2x\config\history.. Retrying once more. > Error : System.IO.IOException: The process cannot access the file 'C:\Program Files\MCEBuddy2x\config\history' because it is being used by another process. > at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) > at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) > at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) > at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost) > at System.IO.File.InternalReadAllText(String path, Encoding encoding, Boolean checkHost) > at SharpConfig.Configuration.LoadFromFile(String filename, Encoding encoding) > at MCEBuddy.Util.Ini..ctor(String file)
Any help is appreciated!
