How to process different types of files without converting
Hi I need some configuration help. I would like MCEBuddy to watch a folder for multiple file formats .TS .WTV .MP4 etc. I need it to strip ads but not convert, so leave the file format as whatever its starts as.
Thanks
Welcome Mick!
You should be able to do what you want by defining three separate conversion tasks.
Task 1: Process TS Recordings
Select the “TS Unprocessed” Profile
Select Ad Remover: Yes(Comskip)
Under Advanced settings put *.ts under File Name Match
Task 2: Process WTV Recordings
Select the “WTV Unprocessed” Profile
Under Advanced settings put *.wtv under File Name Match
Task 3: Process MP4 Recordings
Select the “MP4 Unprocessed” Profile
Under Advanced settings put *.mp4 under File Name Match
I convert everything to MP4 except for my Playlater items. For those I use the same settings for Task 3 only I have the expert setting to check for “Check chapters for Ad markers”.
Good luck!
