How to import EPG Data from DVBViewer
Thanks to @oweindl for this script
This is a powershell script to Import DVBViewer EPG Data to MCEBuddy (converts the .TXT from DVBViewer INI to a NPVR compatible XML)
Step 1
Download the file convert.ps1 and save it in the folder c:\tools as c:\tools\convert.ps1
Step 2
Add the following to your profile
PreMetaCustomCommandPath=C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe
PreMetaCustomCommandParameters=-executionpolicy unrestricted -file c:\tools\convert.-ps1 ""%sourcefile%""
PreMetaCustomCommandHangPeriod=0
PreMetaCustomCommandCritical=false
PreMetaCustomCommandUISession=false
PreMetaCustomCommandShowWindow=false
PreMetaCustomCommandExitCodeCheck=false
Just a note, as i just hit this issue. Whern upgrading (uninstall and re-instrall) profile configuration is beeing reset. So the PreMetaCustomCommands need to be re-edited…
