Hi,
I have being recording some videos with Jaksta… it works fine, but it leaves this fugly black lines to the sides.
It seems that auto crop will not work because there are some non-black pixels.
But my videos are consistent in size… how can I create a profile that crops those?
Thank you for your help
I don’t know for certain, but you might try changing the encoder order in the profile - handbrake is pretty good at finding and cropping out those black bars - I’m not sure that FFMPEG is as good.
If that doesn’t work, you might try tweaking the profile manually. The CLI documentation for handbrake is here: HandBrake Documentation — Command line reference
