Can’t install says “Error 1001. The specified service already exists”
I rebooted many times deleted left over folder from the many failed installs no luck same error.
Version 2.6.1 and 2.6.2 gives same problem.
Did you uninstall previous version?
Yes many times
Try these instructions.
The 2nd command “sc delete MCEBuddy2x” did the trick. The “sc stop MCEBuddy2x” command said it wasn’t running.
Thanks!!
