KMTTG has an option to export a text metadata file from the Tivo recording it is downloading.
Is there any way to have MCEBuddy include this by default and rebuild the metadata info?
Some fields seem to be named differently (like “callsign”), and I suggest that MCEBuddy have a mapping for this.
“displayMajorNumber” is the guide’s HDTV Channel #, e.g. 9-4 is station channel 9.4.
“callsign” is the broadcast channel’s callsign, which should translate to MCEBuddy’s “Channel” selection field which I use to filter the profile for processing quality based on an HD or SD channel. Most stations only broadcast full HD content (1080i/720p) on their primary channel, and all of the sub-channels get SD (640x480). For that reason, I don’t want to over-compress an already low-quality source that has likely already also been transcoded or never was an HD source to begin with.
I did some processing with the raw Tivo file and had MCEBuddy do the decrypting. In the resulting file, all of the metadata was replaced by the IMDB entry (I have a forced override rule setup for this show as the guide uses multiple titles “ATK” or “ATK from Cook’s Illustrated” for earlier seasons.)
We can look into it, if you have the metadata file available, but MCEBuddy also extracts the metadata from the TiVO file. Is there a difference? We would need a the original TiVO file (MAK key), the data you extracted and then we can compare it. BTW you log file is set is not set to debug there’s it’s practically empty.
Just a marker for myself to take another run at this. It is still happening in the current version (2.5.8 2022-10-12).
Meaning I get a text file with the Tivo metadata extract, but the processed file doesn’t include any of that and only includes TheTVDB metadata and dumps the recording into my “Specials” output folder. This tells me that the earlier tasks that process TV shows based on recording channel didn’t have any metadata (from the Tivo extract file) used to determining this.
I believe that MCEBuddy already processed the metadata file as long as it has the same name as the original file. If you don’t think so then we will need samples of different types of metadata, movies, series, news, sports etc.
