Lately I’ve been getting the same error message when I try to convert ISO files to MKV using the MKV Unprocessed profile. Any suggestions?
ERROR> 2019-07-11T12:19:21 MCEBuddy.AppWrapper.FFmpegMediaInfo --> ERROR Processing FFProbe Output.System.NullReferenceException: Object reference not set to an instance of an object.
at MCEBuddy.AppWrapper.FFmpegMediaInfo.ParseFFPROBEMediaInformation(String StdOut)
Odd, because it’s worked with other ISOs. I successfully ran an ISO (log attached) through MCEBuddy earlier with the same settings that had otherwise given me errors.
Possibly, MCEBuddy expects a video container. ISO is a generic container and not a video container. It may have worked with DVD ISO’s but that’s probably because the profile you’re using uses FFMpeg which happens to support it.
