Comskip Profiles for Xfinity
I’m looking for anyone out there that could share a good general comskip profile I can use for Xfinity. I am recording mostly from History Channel, Travel Channel, Smithsonian and Science Channel. I record thru Emby and HDHomeRun Prime.
Check out some of the custom comskip profiles contributed by the community here
You can also ask the AI bot customize your comskip ini profiles. The more specific you are in your request the better it works and I’ve seen t generate some pretty good customizations. Be specific like describe the show, it has logos or what you of show if it’s sports or movies or if it has closed captions and if the ads are short or long etc. more information you can give the AI bot the better will work. It’s been trained on comskip INI customizations.
