What happened to the Client Installer for 2.5.5? Download appears to be a portable version.
The remote client is MCEBuddy.GUI.exe in the Remote Client zip. The remote client installer is not required since it limits you to install the remote client just once. With this release you can use the remote client multiple times from different folders to connect multiple engines from a single remote machine.
I see, thanks
