64 bit
Windows 7 64
I am converting video recorded using PlayOn. Original file is fine. Comskip with markers, select best sound track unchecked, Cut 3 seconds off beginning cut 8 seconds off end, MP4 Fast (audio ever so slightly off), MP4 Normal (bad), Ucompressed (worst). I’m using a windows 7 PC my work was getting rid of to use as a plex server and video recorder. Everything works great but the one thing I thought would work best was MCEBuddy and this is the thing that isn’t working properly. I’m not a coder. Can someone help? I’ve tried reinstalling but no luck. Found other forum post about this topic but no help.
I dont’ see any obvious errors in your video recording but do I see that there’s an sync delay between your video and audio streams defined in the container:
You can try to set the ffmpeg-audiodelay parameter to auto in your profile (see the advanced commands) OR you can correct the sync yourself but setting the audio correction offset in the Conversion Task -> Expert Settings page
This parameter is set for each encoder type, e.g. ffmpeg, mencoder or handbrake
When xxx is set to skip then it tells MCEBuddy to skip auto correction of audio delay (sync). This is useful for some file formats such as AVI where audio gets skewed on auto correction.
If this parameter is set to a numerical value, then this parameter is used to manually specify the audio delay correction to correct audio sync, xxx is a +ve or a -ve number in seconds.
A value of 0 means that MCEBuddy will skip any delay correction.
If the value is equal to auto , it adds or subtracts the delay specified to the auto calculated audio delay for the video.
Thank you for the response. I didn’t notice the audio delay option. However I would like to know how to do the auto delay correction but again I’m not a programmer and I wouldn’t even know how to get to the code line in order the change it. would you be able to give me a quick walkthrough on how to do it? I mostly want this in case I want to change settings without having to figure out exactly how much delay there is every time. Thank you again so much
