Request Type:
BUG - install of 64 beta crashed and cannot uninstall
Windows 10 PC 64bit Gateway desktop
java installed and updated
the MCEBuddy 64bit Beta program did not fully install - no log file
Unable to remove it from my PC
This was on a new install of Windows 10 OS should have been no conflicts
I cannot install the stable version over the beta version and there is no way to delete the old partially installed beta version. When I try to install the stable version I get the “Another version …use the Add/remove Program on the Control panel.”
I get the following error message on a control panel uninstall:
Error 1001. Exception occurred while initializing the installation
System .IO FileNotFoundException Could not load file or assembly file:///C:\Program Files\MCEBuddy2x\MCEBuddy.Service.exe’ or one of its dependencies. The system cannot find the file specified.
Then it shows the program still installed.
I’m dead in the water until I can figure a way to delete the 64bit beta version of the program
