Season missing substitution
Is there a way to substitute if no field exists?
Example, when doing custom file renaming if I set ‘\Season %season%##’ and there is no season number available for the show, can I substitute 00 for the ##
Without a season number, I am getting the wrong metadata in my Media Player.
Yes, see the advanced settings and commands documentation page → the renaming section. There is a renaming option called %ifseason% which does what you’re looking for.
Thanks, That command worked perfectly.
