Original ts files are not getting deleted, I have delete original file check.
Profile
[emby]
SearchPath=D:\EmbyDVR
SearchPattern=*.dvr-ms;*.wtv;*.asf;*.avi;*.divx;*.dv;*.flv;*.gxf;*.m1v;*.m2v;*.m2ts;*.m4v;*.mkv;*.mov;*.mp2;*.mp4;*.mpeg;*.mpeg1;*.mpeg2;*.mpeg4;*.mpg;*.mts;*.mxf;*.ogm;*.ts;*.vob;*.wmv;*.tp;*.tivo
SearchPathExclude=
DeleteMonitorOriginal=True
ArchiveMonitorOriginal=False
ArchiveMonitorPath=
MonitorSubdirectories=True
MonitorConvertedFiles=False
ReMonitorRecordedFiles=False
MinimumAge=3
DomainName=
UserName=
LOG
INFORMATION> 2019-06-27T23:17:44 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2019-06-27T23:17:44 MCEBuddy.Engine.ConversionJob --> Finished custom command, file size [KB] 4,696,759.00
INFORMATION> 2019-06-27T23:17:44 MCEBuddy.Engine.ConversionJob --> Moving converted file to destination
INFORMATION> 2019-06-27T23:17:44 MCEBuddy.Engine.ConversionJob --> Moving converted file C:\Program Files\MCEBuddy2x\working0\S07E06-Command Delete.mkv to E:\Emby DVR\Elementary\Season 07\S07E06-Command Delete.mkv
INFORMATION> 2019-06-27T23:18:33 MCEBuddy.Engine.ConversionJob --> Running custom commands
2019-06-27T23:18:33 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
PostCustomCommandPath =
PostCustomCommandParameters =
PostCustomCommandHangPeriod = 300
PostCustomCommandCritical = False
PostCustomCommandUISession = False
PostCustomCommandShowWindow = True
PostCustomCommandExitCodeCheck = False
INFORMATION> 2019-06-27T23:18:33 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2019-06-27T23:18:33 MCEBuddy.Engine.ConversionJob --> Finished end of conversion custom command, file size [KB] 4,696,759.00
INFORMATION> 2019-06-27T23:18:33 MCEBuddy.Engine.ConversionJob --> Success - All done!
--> Performance Metrics for the Current Conversion
--> Working video pre-conversion duration (hh:mm:ss) -> 00:54:44
2019-06-27T23:18:33 MCEBuddy.Engine.ConversionJob --> Original file size [KB] 5,972,764.00
--> Dumping complete information about the file D:\EmbyDVR\Elementary (2012)\Season 7\Elementary S07E06 Command Delete.ts
2019-06-27T23:18:33 MCEBuddy.AppWrapper.Base --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2019-06-27T23:18:33 MCEBuddy.AppWrapper.Base --> Process arguments -hide_banner -probesize 100M -analyzeduration 300M -i "D:\EmbyDVR\Elementary (2012)\Season 7\Elementary S07E06 Command Delete.ts"
2019-06-27T23:18:33 MCEBuddy.AppWrapper.Base --> UI Session Admin Process : False
2019-06-27T23:18:33 MCEBuddy.AppWrapper.Base --> Setting process priority to Normal
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> [mpeg2video @ 00000177d7beb300] Invalid frame dimensions 0x0.
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Last message repeated 9 times
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> [mpegts @ 00000177d7be8e40] PES packet size mismatch
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Last message repeated 1 times
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Input #0, mpegts, from 'D:\EmbyDVR\Elementary (2012)\Season 7\Elementary S07E06 Command Delete.ts':
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Duration: 01:05:57.53, start: 55443.965278, bitrate: 12363 kb/s
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Program 3
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Stream #0:0[0x31]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 1920x1080 [SAR 1:1 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Stream #0:1[0x34](eng): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 384 kb/s
2019-06-27T23:18:34 MCEBuddy.AppWrapper.Base --> Stream #0:2[0x35](spa): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s (visual impaired)
--> Process exited with code 0
--> <Start At Date/Time> <Duration (hh:mm:ss)> <Activity>
--> <06/27/2019 23:08:26> <00:00:00> <Running custom commands>
--> <06/27/2019 23:08:26> <00:00:10> <Getting show information and banner from Internet sources>
--> <06/27/2019 23:08:36> <00:00:00> <Running custom commands>
--> <06/27/2019 23:08:36> <00:00:02> <Checking for disk space>
--> <06/27/2019 23:08:38> <00:00:27> <Copying source file to working directory>
--> <06/27/2019 23:09:06> <00:00:00> <Trimming video recording>
--> <06/27/2019 23:09:06> <00:00:07> <Analyzing video information>
--> <06/27/2019 23:09:14> <00:05:37> <Advertisement scan>
--> <06/27/2019 23:14:51> <00:00:00> <Running custom commands>
--> <06/27/2019 23:14:51> <00:01:40> <Removing commercials>
--> <06/27/2019 23:16:31> <00:00:14> <Analyzing video information>
--> <06/27/2019 23:16:46> <00:00:13> <Analyzing video information>
--> <06/27/2019 23:16:59> <00:00:41> <Converting>
--> <06/27/2019 23:17:41> <00:00:02> <Writing show information>
--> <06/27/2019 23:17:44> <00:00:00> <Renaming file using show information>
--> <06/27/2019 23:17:44> <00:00:00> <Running custom commands>
--> <06/27/2019 23:17:44> <00:00:49> <Moving converted file to destination>
--> <06/27/2019 23:18:33> <00:00:00> <Running custom commands>
--> <06/27/2019 23:18:33> <00:00:00> <Success - All done!>
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:10:07
