So for some reason my HEVC MKV conversion profile is causing the converted WTV file to lose it’s AC3 Audio Track and only have Stereo. I’ve double checked that Mult-Channel Audio is selected in the settings (along with choose the best audio track), so I am not sure what would be causing this. Could someone look over a Log File and see what I probably have setup wrong?
Just to follow up…I updated the HEVC MKV profile to copy audio instead of whatever it was doing before and I still got the same result with only stereo in the converted Audio file.
[HEVC MKV]
Description=HEVC in MKV (H.265/AC3) conversion. Creates a smaller file (50% smaller than H.264) with comparable quality but very slow.
order=handbrake,ffmpeg
ffmpeg-general=-threads 0
ffmpeg-video=-ss 0 -vf yadif=0:-1:1,hqdn3d -vcodec libx265 -preset medium -crf 18 -map 0:v -sn
ffmpeg-audio=-acodec copy -map 0:a
ffmpeg-ext=.mkv
ffmpeg-audiodelay=skip
handbrake-general=--decomb --loose-anamorphic --verbose=2
handbrake-video=--start-at duration:0 -e x265 --encoder-preset medium -q 18
handbrake-audio=-E ffac3 -R auto -B 160 -D 0 -a 1,2,3,4,5
handbrake-audioac3=-E ffac3 -R auto -B 256 -D 0 -a 1,2,3,4,5
handbrake-ext=.mkv
handbrake-audiodelay=skip
I didn’t touch anything in the Handbrake section of the profile so I am guessing that something is happening during the conversion to H.265 that is changing the audio track.
Any thoughts on this?
Your converted file (output) is showing 5.1 channel audio:
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> Input #0, matroska,webm, from ‘C:\Program Files\MCEBuddy2x\working0\Archer_FXXPHD_2018_05_20_01_58_00.mkv’:
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> Metadata:
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> ENCODER : Lavf58.0.102
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> Duration: 00:21:13.28, start: 0.000000, bitrate: 2344 kb/s
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> Stream #0:0: Video: hevc (Main), yuv420p(tv, progressive), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps, 59.94 tbr, 1k tbn, 59.94 tbc (default)
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> ENCODER : Lavc58.1.100 hevc_nvenc
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> DURATION : 00:21:13.277000000
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 256 kb/s (default)
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> ENCODER : Lavc58.1.100 ac3
2018-10-11T07:16:53 MCEBuddy.AppWrapper.Base --> DURATION : 00:21:13.202000000
