Hi,
Recently decided to play around with MCEBuddy to try and speed up my TV recording processing. As I understand, recordings are formated as h264 and AC3 so all I really need is to make it an mp4/mkv, subs extracted and comercials cutted. I’ve been using ffmpeg quite a bit recently and decided to test a few things with “codec copy”. So after testing a few files manually I realised I only had to manipulate a profile to specifically do this. I’ve configured a profile in MCE and tested - which worked ok - but found a few issues in the logs:
I have just put together this new PC with a Gen 10 core i5 processor, still using my old GT630 card (waiting for a new one). I noticed HW encoding is not detected
Also, even having ffmpeg as the first option, it tries to use handbrake first before failing.
What’s wrong with my config or where should I look?
Anything else wrong with my config? I want to ignore handbrake or at least have similar “codec copy” as the fallback
log uploaded : MCEBuddyLog - Pastebin.com
