Thanks to JoshDi for putting this together:
I created a BAT file script to help coordinate distributed MCEBuddy conversions across my two machines: HTPC and HTPC-Bedroom (Bedroom)
I run the following script every 5 minutes on both machines via task manager. No schedule is set (start stop) in MCEBuddy - the script handles the starting and stopping of MCEBuddy Conversions.
Essentially the script does the following:
- Checks to see if Media Center or Kodi is running locally. If so, stop running MCEBuddy on the local machine
- If Media Center or Kodi are NOT running locally on HTPC, run MCEBuddy conversions on HTPC and stop conversions on Bedroom if MCEBuddy is converting files.
- If Media Center or Kodi are NOT Running locally on Bedroom and MCEBuddy is not already running conversions on HTPC, start MCEBuddy conversions on Bedroom
In summary, if Kodi or Media Center are running the script assumes that the machine is being used and to not run conversions on that machine. The script will then try to run conversions first on HTPC and then Bedroom - ensuring that MCEBuddy conversions are not running on both machines.
You will need to change the following in the script below:
- 192.168.1.50 is the IP of my HTPC
- 192.168.1.60 is the IP of my Bedroom
- The two IF “%SERVER%” lines need to be changed to the respective hostnames of the two machines
- Please also ensure that C:\temp\ is writable, if not please change the paths below.
@echo off&setlocal
SETLOCAL EnableExtensions
REM ***************************************
REM START VARIABLES
del /Q /F C:\Temp\MCEBuddyControlLastRun.txt
For /f "tokens=2-4 delims=/ " %%a in ('date /t') do (set mydate=%%c-%%a-%%b)
For /f "tokens=1-2 delims=/:" %%a in ('time /t') do (set mytime=%%a%%b)
echo %mydate%_%mytime% > C:\Temp\MCEBuddyControlLastRun.txt
set SERVER=%computername%
set EXE1=Kodi.exe
set EXE2=ehshell.exe
set LOGFILE=C:\Temp\mcestatus.log
SET statusFileHTPC=C:\Temp\HTPC.mcestatus
SET statusFileBEDROOM=C:\Temp\BEDROOM.mcestatus
REM END VARIABLES
REM echo %SERVER%
IF "%SERVER%"=="HTPC-PC" GOTO HTPC
IF "%SERVER%"=="HTPC-BEDROOM" GOTO BEDROOM
:HTPC
echo Initalizing variables for HTPC > %LOGFILE%
set IP="192.168.1.50"
REM set CHECK=Z:\Recorded TV\HTPC.mcerunning
REM echo %IP%
REM pause
GOTO STEP1
:BEDROOM
echo Initalizing variables for Bedroom > %LOGFILE%
set IP="192.168.1.60"
REM echo %IP%
REM pause
GOTO STEP1
:STEP1
REM echo "STEP 1"
REM pause
REM CHECK if BEDROOM is up
ping -n 1 192.168.1.50 > NUL
IF ERRORLEVEL 0 (echo HTPC is up, continue >> %LOGFILE%) ELSE (echo HTPC is NOT up, ENDING >> %LOGFILE% && goto END)
REM CHECK MCEBuddy Run Status
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=query --action=enginestate --server=192.168.1.50 --port=23332 --quiet > %statusFileHTPC%
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=query --action=enginestate --server=192.168.1.60 --port=23332 --quiet > %statusFileBEDROOM%
SET /P statusHTPC= < %statusFileHTPC%
SET /P statusBEDROOM= < %statusFileBEDROOM%
del /Q /F %statusFileHTPC%
del /Q /F %statusFileBEDROOM%
echo MCEBuddy HTPC: %statusHTPC% >> %LOGFILE%
echo MCEBuddy Bedroom: %statusBEDROOM% >> %LOGFILE%
REM echo %statusHTPC%
REM echo %statusBEDROOM%
REM if %statusHTPC% == started (echo "HTPC STARTED")
REM if %statusHTPC% == stopped (echo "HTPC STOPPED")
REM if %statusBEDROOM% == started (echo "BEDROOM STARTED")
REM if %statusBEDROOM% == stopped (echo "BEDROOM STOPPED")
REM pause
GOTO STEP2
:STEP2
REM echo "STEP 2"
REM pause
REM CHECK IF KODI or MediaCenter is Running
FOR /F %%x IN ('tasklist /NH /FI "IMAGENAME eq %EXE1%"') DO IF %%x == %EXE1% goto ProcessFound
FOR /F %%x IN ('tasklist /NH /FI "IMAGENAME eq %EXE2%"') DO IF %%x == %EXE2% goto ProcessFound
goto ProcessNotFound
:ProcessFound
echo Kodi or MediaCenter is Running >> %LOGFILE%
REM pause
REM echo %EXE% is running
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=stop --server=127.0.0.1 --port=23332 --quiet
goto END
:ProcessNotFound
echo Kodi or MediaCenter NOT Running >> %LOGFILE%
REM pause
REM echo %EXE% is not running
IF "%SERVER%"=="HTPC-PC" GOTO CHECKHTPC
IF "%SERVER%"=="HTPC-BEDROOM" GOTO CHECKBEDROOM
goto END
:CHECKHTPC
echo Running MCEBuddy Check for HTPC >> %LOGFILE%
REM pause
SetLocal EnableDelayedExpansion
echo MCEBuddy: HTPC Running >> %LOGFILE%
echo MCEBuddy Already Running on HTPC >> %LOGFILE%
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=rescan --server=192.168.1.50 --port=23332 --quiet
REM pause
EndLocal
if %statusHTPC% == conversion_in_progress (
REM pause
EndLocal
echo MCEBuddy: HTPC Stopped >> %LOGFILE%
echo Starting MCEBuddy on HTPC >> %LOGFILE%
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=start --server=192.168.1.50 --port=23332 --quiet
REM schtasks /Run /TN "\HTPC\UnlockScreen"
REM pause
EndLocal
REM Stop Bedroom if started
if %statusBEDROOM% == started ("C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=stop --server=192.168.1.60 --port=23332 --quiet)
if %statusBEDROOM% == conversion_in_progress ("C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=stop --server=192.168.1.60 --port=23332 --quiet)
goto END
:CHECKBEDROOM
echo Running MCEBuddy Check for BEDROOM >> %LOGFILE%
REM pause
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=rescan --server=192.168.1.60 --port=23332 --quiet
REM pause
EndLocal
REM pause
EndLocal
echo MCEBuddy: Bedroom Running >> %LOGFILE%
echo MCEBuddy Already Running on Bedroom >> %LOGFILE%
REM pause
) ELSE IF %statusBEDROOM% == conversion_in_progress (
REM pause
) else (
echo MCEBuddy: Bedroom Stopped >> %LOGFILE%
echo Starting MCEBuddy on Bedroom >> %LOGFILE%
"C:\PROGRA~1\MCEBuddy2x\MCEBuddy.UserCLI.exe" --command=engine --action=start --server=192.168.1.60 --port=23332 --quiet
REM pause
EndLocal
goto END
:END
:: Exit code 0
Ver > nul
REM pause
EXIT
