Unhandled exception adding correction in in expert settings for new conversion task
Request Type:
BUG [MINOR]
MCEBuddy Version and Type (32bit or 64bit): 2.5.1 2019-08-12
Operating System and Type (32bit or 64bit): WIn10x64
Unhandled Exception occurs attempting to add a correction in the expert settings of brand new conversion task (before saving the new task). Workaround is to click the “Continue” button and the dialog is constructed properly with an empty list of corrections.
Steps to replicate the bug:
In Settings, Add new Conversion Task. Give it a name. Click on “Expert Settings”. Click on “Corrections”. Error should occur. Workaround is to click on “Continue”.
I suspect the app is not checking to initialize the list/array when the Corrections button is pressed. It gets initialized when you press “Continue” and the dialog opens normally, ready to add the first correction. This is a new conversion task, so there is no persisted/saved task (yet) that would normally initialize these (defaulted empty) sub-object structures as part of the save/persist method or in the load/deserialize method if this conversion task already existed.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of ‘-2147483648’ is not valid for ‘SelectedIndex’.
Parameter name: SelectedIndex
at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at MCEBuddy.GUI.ConversionTaskSetSeriesIDForm.SetSeriesId_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.3815.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
MCEBuddy.GUI
Assembly Version: 2.5.1.0
Win32 Version: 2.5.1.0
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/MCEBuddy.GUI.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.3801.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MCEBuddy.Globals
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/MCEBuddy.Globals.DLL
MCEBuddy.Configuration
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/MCEBuddy.Configuration.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
MCEBuddy.ProgressODoom
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/MCEBuddy.ProgressODoom.DLL
MCEBuddy.Util
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/MCEBuddy.Util.DLL
Newtonsoft.Json
Assembly Version: 9.0.0.0
Win32 Version: 9.0.1.19813
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/Newtonsoft.Json.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
Win32 Version: 4.8.3825.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
SharpConfig
Assembly Version: 3.2.0.0
CodeBase: file:///C:/Program%20Files/MCEBuddy2x/SharpConfig.DLL
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
SMDiagnostics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
System.IdentityModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Microsoft.CSharp
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Thanks for pointing it out, fixed in today’s build.
