Playon/mcebuddy combo
playon
#1
Anyone converting video with Playon and then permanently removing commercials with mcebuddy? Any suggestions for ideal settings as it is not working very well for me.
(RBoy) #2
Commercial removal settings depend on the channel and your provider, not the recorder.
See the section on how to tweak comskip settings.
(John Dugger) #3
Actually, PlayOn includes chapter markers that mark the beginning and end of each advertisement. You should use the following settings to have MCEBuddy automatically chop at those markers:
Profile: MP4 Unprocessed
Ad remover: Yes (Use markers)
Then, under Advanced Settings -> Expert Settings:
Check chapters for Ad markers: checked
That will rapidly and without loss of quality remove the commercials that PlayOn has already marked. Always check the recording after you’ve removed commercials as sometimes PlayOn may miss marking a commercial; however, it’s much more reliable than using comskip to try to detect the commercials since PlayOn’s commercial detection occurs during the streaming processes and is based on recognizing a change in the video source.
Hope this helps!
