How do all of John Walshs Omega XL commercials get thru Comskip
I would suspect that it is because of the length of the commercial. There is a setting in Comskip which identifies by length of time which segments are actually commercials. If that individual segment time is long enough (I think its default is 5 minutes) anything that is that long or longer it automatically considers it to be part of the show and leaves it in the final file as a show segment instead of cutting it as a commercial. Humana Medicare commercials sometimes do the same thing. They’re not commercials at that length - they are infommercials stuffed into the middle of a show.
The same thing is true for show segments that get cut out. Judge Judy shows are famous for this. It returns from a commercial and Judge Judy speaks for 20 or 30 seconds rendering a verdict and then closes the case. All told for that segment for the final verdict might be 60 seconds. Comskip thinks that anything less than 60 seconds is a commercial and cuts it out from the final string on segments. Took me a while to figure that out and my wife was fussing she would never see how the case was decided. As we all know, if the wife factor isn’t happy, then we have wasted time and money to put a dumb system in place that doesn’t work. :sunglasses:
Hope that helps.
RT
