# Adjust EDL file and Chapters when CUT START is used
**URL:** https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630
**Category:** Bugs
**Created:** [March 31, 2018, 12:06pm UTC](https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630 "2018-03-31T12:06:30Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![BrianGGG](https://discussion.mcebuddy2x.com/user_avatar/discussion.mcebuddy2x.com/brianggg/32/461_2.png) [@BrianGGG](https://discussion.mcebuddy2x.com/u/BrianGGG)
#### Post date: [March 31, 2018, 12:06pm UTC](https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630/1 "2018-03-31T12:06:30Z")
</div>
**Request Type:**
Feature
**MCEBuddy Version and Type (32bit or 64bit):**
2.4.9
**Operating System and Type (32bit or 64bit):**
Win 10 64bit
**Summary of the problem or suggestion:**
If an existing EDL file is used, and the CUT START feature is used, chapters are out of sync.
The EDL File should be adjusted based on the CUT START value (e.g. if cut start is set to 12 seconds, all of the EDL entries should be shifted forward 12 seconds).
Same is true when Chapters are carried forward.
Reference:
> [@EDL not adjusted when Cut Start is specified](https://discussion.mcebuddy2x.com/t/edl-not-adjusted-when-cut-start-is-specified/1626/2):
> I don’t think the chapter markers are adjusted for manual cuts (they are adjusted for commercial cuts), they probably should be. Worthy of an enhancement ticket. EDIT: Even saved EDL’s aren’t adjusted for manual trimming (only subtitles are adjusted for trimming), so both chapters and saved EDL’s should probably be adjusted for manual trimming.
### Author: ![Goose](https://discussion.mcebuddy2x.com/letter_avatar_proxy/v4/letter/g/5f9b8f/32.png) [@Goose](https://discussion.mcebuddy2x.com/u/Goose)
#### Post date: [May 24, 2018, 10:06pm UTC](https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630/2 "2018-05-24T22:06:20Z")
</div>
Been investigating this, MCEBuddy itself adjusts for the cut START and cut END while processing the EDL file and cutting the video. However it does not modify the original EDL file.
So if you’re removing the commercial it should work fine. I’m guessing in your case you’ve only detecting commercials and not actually cutting them. Is that correct? Can you attach your conversion log?
#### Post date: [May 25, 2018, 12:45pm UTC](https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630/3 "2018-05-25T12:45:48Z")
</div>
Thanks for looking into this.
Your assumption is correct: I have an existing EDL file (created at recording time by ComSkip), and I have CUT START set in my MCEBuddy task. The ultimate goal is to set chapter markers in the resulting file to skip commercials rather than cut them.
I don’t have any existing LOG files that are still active. I’ll try to stage this problem and will post new logs …
#### Post date: [May 25, 2018, 3:28pm UTC](https://discussion.mcebuddy2x.com/t/adjust-edl-file-and-chapters-when-cut-start-is-used/1630/4 "2018-05-25T15:28:36Z")
</div>
Okay I think we’ve solved the issue in a better way. If a saved EDL file is found, MCEBuddy will correct the EDL itself to adjust for any trimming and remuxed skipped seconds etc so that all downstream operations (chapters, subtitles, cutting commercials etc) are properly synchronized.
Try today’s 2.4.9 BETA build. I’m closing the ticket, if it’s an issue please reopen with the conversion log
