Renaming Issue with PBS NOVA
The Nova Series from PBS is not finding the series number and names in the databases. I have a metadata correct error that provides the IMDB and tvdb series ID. The problem is, it is saving the file as NOVA - S99E99 -.mp4.
Custom Renaming Rule is: TVShows%showname%\Season %ifseason%<%season%##,99>%showname% - S%ifseason%<%season%##,99>E%ifepisode%<%episode%##,99> - %episodename%
--> Starting conversion - DEBUG MESSAGES
INFORMATION> --> Windows OS Version -> Microsoft Windows NT 6.3.9600.0 (WIN_8_1_2013_SERVER_R2, Standard Edition)
INFORMATION> --> MCEBuddy Build Version : 2.4.8.1
INFORMATION> --> MCEBuddy Build Date : 01/24/2018 16:02:36
--> Domain Name ->
User Name -> Guest
Password ->
Wake Hour -> -1
Wake Minute -> -1
Start Hour -> -1
Start Minute -> -1
Stop Hour -> -1
Stop Minute -> -1
Days of Week -> Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday
Max Concurrent Jobs -> 8
Enable Job Logs -> True
Log Level -> 3
Log Keep Days -> 15
Use Recycle Bin -> False
Delete Manually/CLI added Original -> False
Archive Manually/CLI added Original -> False
Sync Converted -> False
Allow Sleep During Conversions -> True
Pause Conversion on Battery Power -> False
Send eMails -> False
eMail settings -> Send eMail Settings -> SMTP Server ->
Port -> 25
SSL -> False
User Name ->
Password ->
From ->
To ->
Bcc ->
eMail On Success -> True
eMail On Failure -> True
eMail On Cancellation -> True
eMail On Start -> True
eMail On Queueing -> True
Skip eMail Body for notifications -> False
Locale -> en-US
Temp Working Path ->
Archive Folder ->
Failed Folder ->
Space Check -> True
Custom Comskip Path ->
Custom profiles.conf ->
App Hang Timeout -> 300
Scan New Files Poll Period -> 60
Process Priority -> Normal
CPU Affinity -> 0
Engine Running -> True
Subtitle Cut Segment Incremental Offset -> 0
Local Server Port -> 23332
UPnP Enabled -> False
Firewall Exception Enabled -> False
--> Task -> Convert to MP4
Profile -> MP4 Normal
Source File -> D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4
Relative Source Path -> Movies
Destination Path -> \\192.168.220.20\PlexMedia1
Working Path -> C:\Program Files\MCEBuddy2x\working0
Fallback Destination -> False
Skip ReProcessing -> False
Add to WMP Library -> False
Max Width -> 1920
Quality Multipltier -> 1
FPS ->
Auto DeInterlacing -> True
Prefer Hardware Encoding -> True
Volume Multipltier -> 0
DRC -> True
Force Stereo -> True
Profile Audio Language ->
Audio Offset -> 0
Start Trim -> 0
End Trim -> 0
Closed Captions ->
Closed Captions Offset -> 2.5
Embed Subtitles -> False
Embed Chapters -> False
Commercial Removal -> None
Custom Comskip INI Path ->
Search Ad markers from chapters -> True
Keep Advertisements -> False
Download Series Details -> True
Download Banner -> True
Overwrite Title from Internet -> False
Metadata Correction => Option 0
Original Title -> NOVA*
Corrected Title ->
TVDB Series Id -> 76119
IMDB Series Id -> tt0206501
Prioritize matching by Original Broadcast Date -> False
Force Show Type -> Default
Write Metadata -> True
Rename by Series -> True
Alt Rename by Series -> False
Custom Rename by Series -> TVShows\%showname%\Season %ifseason%<%season%##,99>\%showname% - S%ifseason%<%season%##,99>E%ifepisode%<%episode%##,99> - %episodename%
Rename Only -> True
File Selection Pattern ->
Show Selection Pattern ->
Channel Selection Pattern ->
Codec Type Selection -> Any
DRM Type Selection -> All
Monitor Tasks Selection ->
Extract XML -> False
Disable Cropping -> False
TiVO MAK Key ->
Domain Name ->
User Name -> plex
Password -> ********
Task Enabled -> True
--> Max Concurrent Jobs -> 8
--> Monitor Root Relative SubFolder Path -> Movies
--> Commercial Skip Cut (profile (CommercialSkipCut) + task) -> True
--> Auto DeInterlacing (profile (AutoDeinterlace) + task) -> True
--> Pre-Conversion Commercial Remover (PreConversionCommercialRemover) -> True
--> Copy LOG File (CopyLogFile) -> False
--> Copy PROPERTIES file (CopyPropertiesFile) -> False
--> Free Space Check -> True
--> Subtitle Cut Segment Incremental Offset -> 0
--> Locale Language -> ENG
--> .NET Framework Version -> 4.0, Service Pack -> 0
INFORMATION> 2018-05-21T08:46:16 MCEBuddy.Engine.ConversionJob --> Current System language is English (United States) (eng)
INFORMATION> 2018-05-21T08:46:16 MCEBuddy.Engine.ConversionJob --> Converting file -> D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4
--> Dumping complete information about the file D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> Process arguments  -hide_banner -probesize 100M -analyzeduration 300M -i "D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4"
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> UI Session Admin Process : False
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> Setting process priority to Normal
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> [mov,mp4,m4a,3gp,3g2,mj2 @ 0000002378decb40] stream 0, timescale not set
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4':
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->   Metadata:
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     major_brand     : isom
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     minor_version   : 512
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     compatible_brands: isomiso2avc1mp41
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Browsepath      : PBS | All Shows | N | NOVA | Episodes | Season 45
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Date            : 0001-01-01T05:00:00
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     HasChapters     : 1
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     MaxSourceFps    : 30.38
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     MinSourceFps    : 29.98
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     PLVF            : 1
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Path            : http://www.pbs.org/video/nova-wonders-whats-living-in-you-fnbfuy/
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Properties      : PFNlcmllc1RpdGxlPk5PVkE8L1Nlcmllc1RpdGxlPjxIYXNBZHZlcnRpc2VtZW50cz5UcnVlPC9IYXNBZHZlcnRpc2VtZW50cz48VmlkZW9JRD41MzY5OGExZC1lNjQ3LTQ3ZjMtODE5Zi02ZmNhZDAwOGQ1ZmI8L1ZpZGVvSUQ+PElEPjUzNjk4YTFkLWU2NDctNDdmMy04MTlmLTZmY2FkMDA4ZDVmYjwvSUQ+PEFkdmVydGlzZW1lbnRzRHV
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     ProviderName    : PBS
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     RecordingTimestamp: 2018-05-10T08:45:14
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     SourceFps       : 29.99
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Sourceid        : http://www.pbs.org/video/nova-wonders-whats-living-in-you-fnbfuy/
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Status          : 2
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Thumbnailurl    : https://image.pbs.org/video-assets/PLszJwZ-asset-mezzanine-16x9-zlbBIKt.jpg.crop.640x360.jpg
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     sort_artist     : NOVA
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     sort_name       : NOVA Wonders What's Living in You?
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     media_type      : 10
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     show            : NOVA
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     artist          : NOVA
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     comment         : Discover how a world of microbes living in and on you can make you sick.
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     title           : NOVA Wonders What's Living in You?
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     encoder         : Lavf57.56.101
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->   Duration: 00:54:21.59, start: 0.042989, bitrate: 3257 kb/s
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Chapter #0:0: start 0.000000, end 4.970000
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->       title           : Video
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Chapter #0:1: start 4.970000, end 34.366000
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->       title           : Advertisement
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Chapter #0:2: start 34.366000, end 3261.361000
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720, 3054 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default)
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->       handler_name    : VideoHandler
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 194 kb/s (default)
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->       handler_name    : SoundHandler
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Stream #0:2(eng): Data: bin_data (text / 0x74786574)
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->       handler_name    : SubtitleHandler
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base -->     Stream #0:3: Video: png, rgb24(pc), 640x360 [SAR 3779:3779 DAR 16:9], 90k tbr, 90k tbn, 90k tbc
2018-05-21T08:46:16 MCEBuddy.AppWrapper.Base --> Unsupported codec with id 100359 for input stream 2
--> Process exited with code 0
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Running custom commands
2018-05-21T08:46:18 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
PreMetaCustomCommandPath =
PreMetaCustomCommandParameters =
PreMetaCustomCommandHangPeriod = 300
PreMetaCustomCommandCritical = False
PreMetaCustomCommandUISession = False
PreMetaCustomCommandShowWindow = True
PreMetaCustomCommandExitCodeCheck = False
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Finished pre metadata custom command, source file size [KB] 1,296,906.00
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Getting show information and banner from Internet sources
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Extracting metadata from file -> D:\Recordings\Movies\NOVA - Wonders What's Living in You.mp4
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Extracting Generic Tags
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Trying to extract Artwork from file
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Read Tags: MPEG4 file detected using AppleTag
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Extracted Generic Tags: Title: NOVA
SubTitle:
Description: Discover how a world of microbes living in and on you can make you sick.
Network: PBS
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 0
Episode: 0
Banner: C:\Program Files\MCEBuddy2x\cache\NOVA Wonders What's Living in You-extract.jpg
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
Is Show Movie: False
Is Show Sports: False
OriginalBroadcastDateTime: 1899-12-31T19:00:00
RecordedDateTime: 2018-05-10T08:45:14
SeriesPremiereDate: 1899-12-31T19:00:00
CopyProtected: False
SageTV FileID:
SageTV MediaFileID:
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Video Tags extracted ->
Title: NOVA
SubTitle:
Network: PBS
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 0
Episode: 0
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
SageTV FileID:
SageTV MediaFileID:
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Trying to match nPVR/SiliconDust series showname -> NOVA - Wonders What's Living in You
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Looking for Season/Episode information in text
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Trying to match Emby series showname -> NOVA - Wonders What's Living in You
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Looking for Title/Subtitle/OriginalBroadcastDT information in Emby text
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Trying to match nPVR movie showname -> NOVA - Wonders What's Living in You
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Trying to extract generic nPVR filename details -> NOVA - Wonders What's Living in You
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Invalid nPVR generic filename
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Video Tags extracted from file/name metadata ->
Title: NOVA
SubTitle:
Network: PBS
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 0
Episode: 0
Banner URL:
IMDB Id:
MovieDB Id:
TVDB Id:
SageTV FileID:
SageTV MediaFileID:
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Checking for metadata title and series correction
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> More than one metadata correction options detected or default title matching detected, matched Original Title -> NOVA*, Series forcing TVDB -> 76119, IMDB -> tt0206501
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Forcing IMDB Title overwrite to true since user has specified IMDB Id
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Forcing TVDB metadata match since user has specified TVDB Id
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Downloading Series details
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Meta correction results, dont' overwrite title -> False
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Recording Type Show
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Checking TheTVDB
--> Matching series from forced TVDBBId (76119)
--> No episode name to match
--> No original broadcast date time
--> No season or episode number availale to match
WARNING> 2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> TheTVDB failed
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData --> Updated Video Tags extracted after downloading details ->
Title: NOVA
SubTitle:
Network: PBS
Network Affiliate:
Parental Rating:
Media Credits:
Genres:
Season: 0
Episode: 0
Banner URL:
IMDB Id: tt0206501
MovieDB Id:
TVDB Id: 76119
SageTV FileID:
SageTV MediaFileID:
--> Custom Renaming Command -> TVShows\%showname%\Season %ifseason%<%season%##,99>\%showname% - S%ifseason%<%season%##,99>E%ifepisode%<%episode%##,99> - %episodename%
WARNING> --> Cannot find Episode Name
PreCustomCommandPath =
PreCustomCommandParameters =
PreCustomCommandHangPeriod = 300
PreCustomCommandCritical = False
PreCustomCommandUISession = False
PreCustomCommandShowWindow = True
PreCustomCommandExitCodeCheck = False
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Finished pre remuxing custom command, source file size [KB] 1,296,906.00
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Checking for disk space
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> File size -> 1.236826 GB
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Destination space -> 13881 GB
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Working space -> 30.11528 GB
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Required free space -> 18.24319 GB
2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Max concurrent conversion jobs -> 8
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Checking for SRT File
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Checking for EDL, EDLP, VPRJ or DTB XML files
INFORMATION> 2018-05-21T08:46:18 MCEBuddy.Engine.ConversionJob --> Checking for Playlater Advertisement Markers
INFORMATION> 2018-05-21T08:46:30 MCEBuddy.VideoProperties.VideoInfo --> Skipping crop information
--> Dumping complete information about the file C:\Program Files\MCEBuddy2x\working0\NOVA - Wonders What's Living in You.mp4
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> Launching process C:\Program Files\MCEBuddy2x\ffmpeg\ffprobe.exe
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> Process arguments  -hide_banner -probesize 100M -analyzeduration 300M -i "C:\Program Files\MCEBuddy2x\working0\NOVA - Wonders What's Living in You.mp4"
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> UI Session Admin Process : False
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> Setting process priority to Normal
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> [mov,mp4,m4a,3gp,3g2,mj2 @ 000000885323cba0] stream 0, timescale not set
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base --> Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Program Files\MCEBuddy2x\working0\NOVA - Wonders What's Living in You.mp4':
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->   Metadata:
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     major_brand     : isom
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     minor_version   : 512
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     compatible_brands: isomiso2avc1mp41
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Browsepath      : PBS | All Shows | N | NOVA | Episodes | Season 45
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Date            : 0001-01-01T05:00:00
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     HasChapters     : 1
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     MaxSourceFps    : 30.38
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     MinSourceFps    : 29.98
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     PLVF            : 1
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Path            : http://www.pbs.org/video/nova-wonders-whats-living-in-you-fnbfuy/
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Properties      : PFNlcmllc1RpdGxlPk5PVkE8L1Nlcmllc1RpdGxlPjxIYXNBZHZlcnRpc2VtZW50cz5UcnVlPC9IYXNBZHZlcnRpc2VtZW50cz48VmlkZW9JRD41MzY5OGExZC1lNjQ3LTQ3ZjMtODE5Zi02ZmNhZDAwOGQ1ZmI8L1ZpZGVvSUQ+PElEPjUzNjk4YTFkLWU2NDctNDdmMy04MTlmLTZmY2FkMDA4ZDVmYjwvSUQ+PEFkdmVydGlzZW1lbnRzRHV
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     ProviderName    : PBS
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     RecordingTimestamp: 2018-05-10T08:45:14
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     SourceFps       : 29.99
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Sourceid        : http://www.pbs.org/video/nova-wonders-whats-living-in-you-fnbfuy/
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Status          : 2
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     Thumbnailurl    : https://image.pbs.org/video-assets/PLszJwZ-asset-mezzanine-16x9-zlbBIKt.jpg.crop.640x360.jpg
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     sort_artist     : NOVA
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     sort_name       : NOVA Wonders What's Living in You?
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     media_type      : 10
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     show            : NOVA
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     artist          : NOVA
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     comment         : Discover how a world of microbes living in and on you can make you sick.
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     title           : NOVA Wonders What's Living in You?
2018-05-21T08:46:30 MCEBuddy.AppWrapper.Base -->     encoder         : Lavf57.56.101
INFORMATION> 2018-05-21T08:46:32 MCEBuddy.Engine.ConversionJob --> Renaming file using show information
INFORMATION> --> Rename file to C:\Program Files\MCEBuddy2x\working0\NOVA - S99E99 -.mp4
INFORMATION> 2018-05-21T08:46:32 MCEBuddy.Engine.ConversionJob --> Running custom commands
2018-05-21T08:46:32 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
CustomCommandPath =
INFORMATION> 2018-05-21T08:46:32 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2018-05-21T08:46:32 MCEBuddy.Engine.ConversionJob --> Finished custom command, file size [KB] 1,296,906.00
INFORMATION> 2018-05-21T08:46:32 MCEBuddy.Engine.ConversionJob --> Moving converted file to destination
INFORMATION> 2018-05-21T08:46:32 MCEBuddy.Engine.ConversionJob --> Moving converted file C:\Program Files\MCEBuddy2x\working0\NOVA - S99E99 -.mp4 to \\192.168.220.20\PlexMedia1\TVShows\NOVA\Season 99\NOVA - S99E99 -.mp4
INFORMATION> 2018-05-21T08:46:34 MCEBuddy.Engine.ConversionJob --> Found EDL file, moving to destination EDL:C:\Program Files\MCEBuddy2x\working0\NOVA - Wonders What's Living in You.edl Destination:\\192.168.220.20\PlexMedia1\TVShows\NOVA\Season 99
INFORMATION> 2018-05-21T08:46:34 MCEBuddy.Engine.ConversionJob --> Running custom commands
2018-05-21T08:46:34 MCEBuddy.Transcode.CustomCommand --> Custom command parameters read ->
PostCustomCommandPath =
PostCustomCommandParameters =
PostCustomCommandHangPeriod = 300
PostCustomCommandCritical = False
PostCustomCommandUISession = False
PostCustomCommandShowWindow = True
PostCustomCommandExitCodeCheck = False
INFORMATION> 2018-05-21T08:46:34 MCEBuddy.Transcode.CustomCommand --> No custom commands found
2018-05-21T08:46:34 MCEBuddy.Engine.ConversionJob --> Finished end of conversion custom command, file size [KB] 1,296,906.00
INFORMATION> 2018-05-21T08:46:34 MCEBuddy.Engine.ConversionJob --> Success - All done!
--> Performance Metrics for the Current Conversion
--> Source video duration (hh:mm:ss) -> 00:54:21
--> Source video codec -> h264
--> Source video height -> 720
--> Source video width -> 1280
--> Pre-conversion video duration (hh:mm:ss) -> 00:54:21
--> <Start At Date/Time>	<Duration (hh:mm:ss)>		<Activity>
--> <05/21/2018 08:46:18>	<00:00:00>		<Running custom commands>
--> <05/21/2018 08:46:18>	<00:00:00>		<Getting show information and banner from Internet sources>
--> <05/21/2018 08:46:18>	<00:00:02>		<Checking for disk space>
--> <05/21/2018 08:46:21>	<00:00:03>		<Copying source file to working directory>
--> <05/21/2018 08:46:24>	<00:00:07>		<Analyzing video information>
--> <05/21/2018 08:46:32>	<00:00:00>		<Renaming file using show information>
--> <05/21/2018 08:46:32>	<00:00:00>		<Running custom commands>
--> <05/21/2018 08:46:32>	<00:00:02>		<Moving converted file to destination>
--> <05/21/2018 08:46:34>	<00:00:00>		<Running custom commands>
--> <05/21/2018 08:46:34>	<00:00:00>		<Success - All done!>
INFORMATION> --> Total time taken by conversion (hh:mm:ss) -> 00:00:16
That’s because the metadata is being taken from your mp4 file and your mp4 file doesn’t have any subtitle or season or episode number.
2018-05-21T08:46:18 MCEBuddy.MetaData.VideoMetaData → Extracted Generic Tags: Title: NOVA
SubTitle:
Season: 0
Episode: 0
It only has a Title and Description. MCEBuddy needs atleast two items to match the metadata on against tvdb/imdb.
Title
AND
Subtitle or Season/Episode or Original Broadcast Date
Without the second piece of information it has not idea what episode it’s trying to look for so you end up with your default 99.
See this:
If you want you can upload the original MP4 file to our servers and we can analyze it further to see what embedded information is available to extract (if any)
I opened a case with playon and yet to hear back from them. Their PBS plugin seems to pull content down, but misses the metadata, around the episode.
The issue may be with nova or pbs. If memory serves me correctly the episode and season numbers were off when I had dish network. If you do find a solution though please post it here.
Thanks
