H265 hardware encoding preset
I have access to h265 encoder (from log file):
2017-11-30T08:44:14 MCEBuddy.AppWrapper.Handbrake --> [08:44:14] - H.265 encoder: yes (8bit: yes, 10bit: yes)
But I am trying to figure out which of the presets will encode to h.265 with hardware. I tried the HEVC MP4 setting and it did not use the HW H265. So basically I think I just need to pick the correct preset but I have no idea what that would be.
Any help is appreciated.
HEVC profiles should use h.265 hardware encoding.
Can you attach your conversion log.
I ended the process early since it was not using the HW encoder. hopefully this gives you enough information if not I can try again.
Chicago P.D. S05E07 20171115 [20171116-0300].mpg-H265-2017-11-30T14-34-16.9910899-06-00.log (1.5 MB)
Upgrade to the latest 2.4.8 BETA version. This issue was fixed last week.
