Thanks to wisermouse for this script, it extracts the metadata in a .ARG (ArgusTV) format:
Step 1: Add the following parameters in your profile:
PreMetaCustomCommandPath=C:\Perl64\bin\perl.exe
PreMetaCustomCommandParameters=c:\code\dvblink.pl %sourcefile%
PreMetaCustomCommandHangPeriod=0
PreMetaCustomCommandCritical=true
Step 2: To use this you just need to copy the code below into a file dvblink.pl
as configured in your profile above:
#!/usr/bin/perl -w
use strict;
use warnings;
use LWP::UserAgent;
use HTTP::Request::Common;
use XML::Simple;
use XML::Parser;
use XML::LibXML;
use Data::Dumper;
use Text::CSV;
use XML::LibXML::PrettyPrint;
use XML::LibXML::Iterator;
use XML::Writer;
my @epg;
main();
sub main
(my $file) = @ARGV;
print 'searching for file =' . $file . "\n\r";
my $message = "command=get_object&xml_param=<?xml version=\"1.0\" encoding=\"UTF-8\" ?> " .
"<object_requester xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"" .
"xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xmlns=\"http://www.dvblogic.com\">" .
" <object_type>-1</object_type>" .
" <item_type>-1</item_type>" .
" <start_position>0</start_position>" .
" <requested_count>-1</requested_count>" .
" <children_request>true</children_request>" .
" <server_address>192.168.0.30/server_address>" .
"</object_requester>";
my $cnt = call_dvblink("127.0.0.1","8080","username","password",$message);
my $objectid1 = get_objectid ($cnt);
#### #second query
" <object_id>$objectid1</object_id>" .
" <server_address>192.168.0.30</server_address>" .
my $ccnt =call_dvblink("127.0.0.1","8080","username","password",$message);
my $objectid2 = get_objectid($ccnt);
##### third query
" <object_id>$objectid2</object_id>" .
parse_list ($ccnt, $file);
sub get_objectid{
my $inputstring = $_[0];
my $parser = XML::LibXML-> new();
my $tree = $parser->parse_string($inputstring);
my $root = $tree->getDocumentElement ;
my $xpc = XML::LibXML::XPathContext->new($root);
$xpc->registerNs("dvbl","http://www.dvblogic.com");
my $rec = $xpc->findnodes('//dvbl:response/dvbl:xml_result');
my ($xmlres) = $rec->get_nodelist;
# print $xmlres;
$xmlres =~ s/\<\;/\</g;
$xmlres =~ s/\>\;/\>/g;
$xmlres =~ s/<\?xml version=\"1.0\" encoding=\"UTF-8\"\?>//g;
$tree = $parser->parse_string($xmlres);
$root = $tree->getDocumentElement;
# my @rec = $xpc->findnodes('//dvbl:object/dvbl:containers/dvbl:container[@dvbl:source_id="8F94B459-EFC0-4D91-9B29-EC3D72E92677"]');
#my @recc = $xpc->findnodes('//dvbl:object/dvbl:containers/dvbl:container/dvbl:object_id[@source_id="8F94B459-EFC0-4D91-9B29-EC3D72E92677"]');
my ($recc) = $xpc->findnodes('//dvbl:object/dvbl:containers/dvbl:container/dvbl:object_id');
my $objectid=$recc->to_literal;
return $objectid;
sub call_dvblink {
# server ip, port username, password, message
my $userAgent = LWP::UserAgent->new(agent => 'perl post');
my $message = $_[4];
$userAgent->credentials($_[0].":".$_[1],"DVBLink Server",$_[2],$_[3]);
my $response = $userAgent->request(POST 'http://'.$_[0].":".$_[1].'/cs/',
Content_Type => 'application/x-www-form-urlencoded',
Content => $message);
print $response->error_as_HTML unless $response->is_success;
return $response->content;
sub parse_list{
my $file = $_[1];
# print $xmlres;
my $name;
my $subname;
my $starttime;
my $plot;
my $channel;\
my $season;
my $episode;
my $recc = $xpc->findnodes('//dvbl:object/dvbl:items/dvbl:recorded_tv');
if ($file =~ m/([0-9]*-[0-9]*-[0-9]+)\.ts/g){
my $id = $1;
foreach my $context ($recc->get_nodelist) {
my $objectid = $context->getElementsByTagName('object_id');
my @tag = split("/",$objectid);
if ($id =~ $tag[1]){
print 'found file '. $file;
my $scheduleid = $context->getElementsByTagName('schedule_id');
my $xpc2 = XML::LibXML::XPathContext->new($context);
$xpc2->registerNs("dvbl","http://www.dvblogic.com");
$name = $xpc2->findnodes('./dvbl:video_info/dvbl:name');
$subname = $xpc2->findnodes('./dvbl:video_info/dvbl:subname');
$plot = $xpc2->findnodes('./dvbl:video_info/dvbl:short_desc');
$channel = $xpc2->findnodes('./dvbl:channel_name');
$episode = $xpc2->findnodes('./dvbl:video_info/dvbl:episode_num');
$season = $xpc2->findnodes('./dvbl:video_info/dvbl:season_num');
$starttime = $xpc2->findnodes('./dvbl:video_info/dvbl:start_time');
my $duration = $xpc2->findnodes('./dvbl:video_info/dvbl:duration');
my $rectime = timestamp($starttime);
$file =~ s/\.ts/\.arg/g;
my $xml = XML::LibXML::Document->new( '1.0', 'utf-8' );
open (MYFILE, '>'.$file);
my $output = '';
my $writer = XML::Writer->new(
OUTPUT=> \$output,
ENCODING => 'utf8',
$writer->xmlDecl('UTF-8');
$writer->startTag('Recording');
$writer->dataElement(ChannelDisplayName => $channel);
$writer->dataElement(Title => $name);
$writer->dataElement(Description => $plot);
$writer->dataElement(RecordingStartTime => (substr $rectime, 5,4). '-'.(substr $rectime, 9,2).'-'.(substr $rectime, 11,2) . ' ' .(substr $rectime, 0,2).':'.(substr $rectime, 2,2));
if ($season->size() > 0){
$writer->dataElement(SeriesNumber => $season);}
if ($episode->size() > 0){
$writer->dataElement(EpisodeNumber => $episode);}
if ($subname->size() > 0){
$writer->dataElement( SubTitle => $subname);
$writer->endTag('Recording');
print MYFILE $output;
close (MYFILE);
sub timestamp {
use warnings;
use strict;
my $time = shift;
die "Usage: $0 [TIME_IN_SECS_SINCE_EPOCH]\n" unless $time;
if ( length($time) > 10 ) {
$time = substr($time, 0, 10);
my @mon = qw( Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec );
my @day = qw( Sun Mon Tue Wed Thu Fri Sat );
my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst)
= localtime($time);
my $ret = sprintf("%02d",$hour) . sprintf("%02d",$min) . "_" . sprintf("%04d%02d%02d",$year+1900, $mon+1, $mday);
return $ret;
