Extra XML files created when using ShowAnalyzer
If you’re facing an issue with ShowAnalyzer creating unnecessary XML files in the output directory along with the converted file, use the following procedure to stop ShowAnalyzer from these creating XML files:
Open the ShowAnalyzer User Interface from the Start Menu:
  • Click SettingsDefault ProfileOutputDVRMSToolBox
  • Double Click on Live to get a drop down box
  • change from Live to Never
  • check Override
  • click Save Changes
If like me you don’t have it in your start menu you can launch ShowAnalyzerUI.exe from C:\Program Files (x86)\Dragon Global\ShowAnalyzerSuite and then the instructions are the same (except it’s Save Changes not save profile).
