Cannot get Hardware Acceleration to work (nvidia)
I keep getting this error in my logs:
2017-11-22T16:15:46 MCEBuddy.Transcode.ConvertWithFfmpeg → Cannot find supported h264/h265 software/hardware encoder combination in profile, disabling auto hardware encoder adjustments
Just updated to the latest BETA version (11/20)
Full Logs here:
Blockquote
→ Checking presence and capabilities of NVidia NVENC Hardware encoder
2017-11-22T16:15:43 MCEBuddy.AppWrapper.NVidiaQuery → Launching process C:\Program Files\MCEBuddy2x\nvidia\nvidiaQuery.exe
2017-11-22T16:15:43 MCEBuddy.AppWrapper.NVidiaQuery → Process arguments
2017-11-22T16:15:43 MCEBuddy.AppWrapper.NVidiaQuery → UI Session Admin Process : True
2017-11-22T16:15:43 MCEBuddy.AppWrapper.NVidiaQuery → Starting process as a UISession process with Admin privileges. This requires atleast 1 user to be logged into the system (remote desktop or locally)
2017-11-22T16:15:43 MCEBuddy.AppWrapper.NVidiaQuery → Setting process priority to Normal
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → C:\Program Files\MCEBuddy2x\nvidia\nvidiaQuery.exe Starting…
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → CUDA Device Query (Runtime API) version (CUDART static linking)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Detected 1 CUDA Capable device(s)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Device 0: “GeForce GTX 1060 6GB”
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → CUDA Driver Version / Runtime Version 9.1 / 7.5
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Detected CUDA Driver version = 9.1
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → CUDA Capability Major/Minor version number: 6.1
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Detected CUDA Hardware version = 6.1
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Total amount of global memory: 6144 MBytes (6442450944 bytes)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → MapSMtoCores for SM 6.1 is undefined. Default to use 128 Cores/SM
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → (10) Multiprocessors, (128) CUDA Cores/MP: 1280 CUDA Cores
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → GPU Max Clock rate: 1835 MHz (1.84 GHz)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Memory Clock rate: 4004 Mhz
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Memory Bus Width: 192-bit
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → L2 Cache Size: 1572864 bytes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Total amount of constant memory: 65536 bytes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Total amount of shared memory per block: 49152 bytes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Total number of registers available per block: 65536
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Warp size: 32
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum number of threads per multiprocessor: 2048
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum number of threads per block: 1024
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Maximum memory pitch: 2147483647 bytes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Texture alignment: 512 bytes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Concurrent copy and kernel execution: Yes with 2 copy engine(s)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Run time limit on kernels: Yes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Integrated GPU sharing Host Memory: No
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Support host page-locked memory mapping: Yes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Alignment requirement for Surfaces: Yes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Device has ECC support: Disabled
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Device supports Unified Addressing (UVA): Yes
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Compute Mode:
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.1, CUDA Runtime Version = 7.5, NumDevs = 1, Device0 = GeForce GTX 1060 6GB
2017-11-22T16:15:44 MCEBuddy.AppWrapper.NVidiaQuery → Result = PASS
→ Process exited with code 0
→ NVidia H.264 Hardware Encoder Detected : True
→ NVidia H.265 Hardware Encoder Detected : True
2017-11-22T16:15:46 MCEBuddy.Transcode.ConvertWithFfmpeg → FFMpeg profile disable software encoder fallback after hardware encoding failure (ffmpeg-DisableSoftwareEncoderFallback) : False
2017-11-22T16:15:46 MCEBuddy.Transcode.ConvertWithFfmpeg → FFMpeg profile optimized for hardware decoding/encoding, disable auto hardware optimization (ffmpeg-UsingHardwareEncoding) : False
INFORMATION> 2017-11-22T16:15:46 MCEBuddy.Transcode.Convert → Converting with FFMpeg
Please dont’ copy paste logs, attach the conversion log so we can get the full picture. Likely your profile has an issue.
Apologies, you can see the log here:
Curious George S07E03 Hundley Jr.; Curious George Gets Winded.ts-Convert to MP4-2017-11-22T16-09-19.8295068-08-00.log (575.7 KB)
The message says that MCEBuddy can’t find a supported format in the configured profile to use a hardware encoder.
That’s correct, you’re using the Profile -> MP4 Unprocessed
It doesn’t encode anything, it copies the original video to preserve quality and format (as mentioned in the profile description). Hence the message.
If you’re using a profile like MP4 Normal or MP4 High Quality you should see the nvenc encoder kick in.
