2.4.9 HW encode Trouble
I have been using MCE buddy successfully a long time now. I tried using this profile found on your forum:
[MKV HVEC Constant Quality]
Description=WARNING: Handbrake Constant Quality encoding (25) with Nvidia HVEC.
order=ffmpeg, handbrake
AllowH264CopyRemuxing=true
FixedResolution=true
SkipCropping=true
AutoDeinterlace=true
ffmpeg-video=-ss 9 -c:v hevc_nvenc -crf 25 -map 0:v
ffmpeg-ext=.mkv
ffmpeg-audiodelay=skip
handbrake-general=–decomb --denoise=“weak” --loose-anamorphic --verbose=2 -T -O
handbrake-video=–start-at duration:3 -e x265 -q 18
handbrake-ext=.mkv
handbrake-audiodelay=skip
The program runs through to the point of conversion, then fails. My video card is a 1030 my driver version is 397.64 running on windows 7x64 with ffdshow (mpeg 2 and avi enabled) and halli media splitter installed. If someone could help me get this running, My CPU (Q6600 with loud fan) and I surely thank you. Uploaded the 3 logs
mcebuddy.log (226.8 KB)
Snatch.wtv-Convert to MP4-2018-10-14T14-02-30.3378906-05-00.log (44.3 KB)
Snatch.wtv-Convert to MP4-2018-10-14T14-09-37.7021484-05-00.log (935.3 KB)
From you log file:
2018-10-14T14:19:56 MCEBuddy.AppWrapper.FFmpeg → Cannot load nvEncodeAPI64.dll
2018-10-14T14:19:56 MCEBuddy.AppWrapper.FFmpeg → [hevc_nvenc @ 0000000008bc1d80] The minimum required Nvidia driver for nvenc is 378.66 or newer
Use the recommended version of the NVidia driver
My driver version is newer… 397.64, Are you recommending a downgrade to 378.66?
Try it, that’s the error from ffmpeg, basically it can’t load your graphics driver modules. It could be a bad install or an unsupported version.
